86 DFI Technical information
  • Roderick
  • Roderick's Avatar Topic Author
3 months 6 days ago
Hello everyone,
I am trying to help out a friend. His 86 DFI runs really bad.
I would like to check the engine timing and the ignition timing.
As I own a 80 Carburated version I do not have the workshop manual of a DFI version.
Is there someone that could share the workshop manual of a 86 DFI or the pages of the workshop manual where engine timing and ignition timing is explained?
Thanks in Advance!
Re: 86 DFI Technical information
3 months 6 days ago
It's available to download free from the bottom of the " Forum" tab. You have to be logged in to see it.
The following user(s) said Thank You: Roderick
  • Roderick
3 months 6 days ago
Thank you, I did not see that.
  • Roderick
3 months 6 days ago
I do try to open the file : KSM-Z1300&KZ1300 (A1thruA5) but it keeps staying at 100% and does not show the file. Do you experience the same?
  • dcarver220b's Avatar
3 months 6 days ago
It opened for me. Try another browser?
  • Roderick
3 months 3 days ago - 3 months 3 days ago
Yes at a other browser it worked thank you.
I see in the file is a wiring diagram for 80,81,82,83 these are all pre DFI. Is there someone with the DFI wiring diagram and maybe the measuring values of the Pick up coils, ignition coils primary and secondary?
Or is it known that the value's should be the same? of the resistance measurements?
Last edit: 3 months 3 days ago by Roderick.
