Cam chain tension
- coleface
Cam chain tension
1 year 2 months ago
After about a 2 year hiatus I'm back finishing the valve adjustment. At the start of this work I pulled the head to check valves and changed the 2 plastic cam chain gears with the steel ones. My question is should the cam chain running over the camshaft be quite tight? Thanks
Re: Cam chain tension
1 year 2 months ago
".....should the cam chain running over the camshaft be quite tight?
Yes. There should be no "slack" in the chain between the cam-shaft sprockets.
- coleface
1 year 2 months ago
Thank you, I'm pretty sure I followed the book when assembling it but like i said after a 2 year away period I sort of forget what I did. I hope to get the 2 valve shims soon and get the engine back together end fired up.
