Valve Clearance Check - 1979 KZ1300
Re: Valve Clearance Check - 1979 KZ1300
3 years 9 months ago - 3 years 9 months ago
Last edit: 3 years 9 months ago by scotch.
Me thinks me thinking is wrong...
if the goal is to dispense exhaust gasses as soon as possible, as long as possible, then one would set clearances to minimum spec not maximum. Minimum specs will lift the valve sooner, and for longer duration, maximizing flow?
Not sure what this really means for <theoretical> cooling effects. First rattle out of the brain box says 'If the ultra hot exhaust gasses are vented ASAP, temps engine combustion temps should be less'?
The 2nd rattle says 'But, what if the real cooling is via valve heat soak and temperature transfer to cooling system?' In that scenario setting to minimum spec makes sense.
That's why I aint no enji-neeeeer!
Still no delivery on cam tools. Sigh.
Well, still waiting for tools. Sigh.
You've got a rattle to find. Chop Chop Wiki Wiki. Valve clearance adjustment to follow.
Good point, as usual.
But phuck Covid home test says positive. So won't leave the house until cleared. May give me time to get some real work done on the KZ. Sigh.
Remind me never to shop Walmart again, that's my best guess of infection.
Time to create page: 0.092 seconds
