1979 z1300 manual tensioner
- Simontwo
5 years 4 months ago
Hello I have a 1979 z1300 with 20,000 miles on it has original tensioner on it I want to fit manual tensioner can I simply unbolt old tensioner and fit new one and adjust up and adjust and that's it start up.and hope for the best thanks simon
Re: 1979 z1300 manual tensioner
Absolutely not. Because the cams may not sit still during your removal/replacement, the cams may jump a tooth. You have to guarantee that when your swap the tensioner out, that nothing moves. After getting the new tensioner in, you must adjust out the slack in the timing chain, then check the timing marks on both of the cams, then roll the crank around with a wrench and check the timing of the cams again and I say this because sometimes especially with the manual tensioner, you may not have taken up all of the slack in the timing chain. As you roll the crankshaft around, check the timing chain for looseness and adjust up as required. ( You'll understand what I'm talking about as your doing it) If you do something stupid like roll it around on the starter and one of the cams ( or both) are out of time, you'll bend a valve(s) and then you'll be pulling the head.
- Simontwo
Hi thanks for your reply I read a other thread about removing and replacing 6 mm bolt and fitting longer bolt. With lock nut does this work thanks simon from Australia
