Clutch cable adjustment help!
  • Akz1300
  • Akz1300's Avatar Topic Author
8 years 4 months ago
Any advice would be great! My clutch was working fine but struggled to get back into neutral when bike hot after riding , so decided to adjust cable following workshop manual, like a fool I didn't record existing settings! What I did exactly wound in adjuster at clutch lever and set 5mm play and locked off, wound in adjuster at clutch lower casing, loosened locknut in clutch, wound out screw until loose as manual, screwed back in until felt tight and back out quarter turn & locked off. Wound out lower adjuster until cable felt tight then adjusted top cable at lever to give 3mm play. When started bike on centre stand put into gear back wheel turns and still turns when I put pressure against tyre, I have turned out lower adjuster a few more turns and readjusted near lever but still the same! What am I doing wrong? It was ok before!
Time to create page: 0.029 seconds
