Big Bore Kit
  • tackelhappy
  • tackelhappy's Avatar
Re: Big Bore Kit
12 years 7 months ago
I would assume that you used an assembly oil/grease when putting the engine parts back together- for instance - on those piston wrist pins. And when you get to the cams and chains etc. , save a litre of oil from the crankcase and pour it over all those parts the best you can.
  • kwak1261
  • kwak1261's Avatar
Re: Big Bore Kit
i think everyone has there own preferences on assembly lubricants.
i use a thin smear of graphite assembly compound just to help while waiting for the oil pressure to build up.
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
  • Don_Karlos
  • Don_Karlos's Avatar
Re: Big Bore Kit
12 years 6 months ago
Hi,
since I'm new to this forum and doesn't like to ask without contributing I wanted to show you what I did with my Big Bore kit which I also bought for very little money from the ebay source in Japan. When the cylinders came back from the machining I was really scared to put them on the Engine! I made contact with Mr. Egli in Swizzerland to get an experienced advice! He said that the wall thickness at the cylinder bottom end is ok :-) But it looks really scary! I will see how it works....
Greetings
Karl
  • Toddh
  • Toddh's Avatar
Re: Big Bore Kit
Karl:
Man those sleeves sure are thin.
It will be interesting to see how those bores hold up over time.
Keep us posted.
Todd.
Last edit: 12 years 6 months ago by Toddh.
  • RickG
  • RickG's Avatar
Re: Big Bore Kit
I would have no hesitation using them with the thin walls as there is so very little stress down there at the bottom of the bores.
  • Don_Karlos
Re: Big Bore Kit
@RickG: This is what Mr. Egli also said and since the Cylinder Sleeves are having more wall thickness inside the block it should not be a problem. We will see.....
Greetings
Karl
Time to create page: 0.048 seconds
