A unique Cam-cover
Re: A unique Cam-cover
8 years 11 months ago
I've certainly used "Scotch-Brite" pads. Went through a ton of them prepping my glider for paint. Outstanding sanding performance but I preferred to use wet paper instead for this project for a number of reasons. Mostly because I'm a sucker for punishment !. But primarily the greater control to remove material exactly where I need to. The "scotch-brite would be perfect perhaps for larger jobs where a polished finish wasn't the goal. :
I found using those pads with Mothers aluminum polish worked best for me. After working it the whole polishing surface gets covered with a grey sludge and gets worked both ways -
the abrasive pad and the chemical polish. It's flexible and easier than sand paper to get to those tight curvy spaces (no pun intended). I always cut off a smaller square from the big pad.
- bassie20
Scotch,
There is one on my second '79 Z1300 I bought last year as well. Never saw one before.
Was going to ask if anyone knows from which year and model they are, but now I see your post.
Looks like original to the '79 engine, but not sure, the bike was pretty messed with.
Last edit: 8 years 10 months ago by Kawboy.
Here it is. It shows on the 1979 - 1980 A1 & A2 parts diagram on the Kawasaki website. It says it's a Canada model.
The following user(s) said Thank You: scotch, bassie20
My Canadian 79 had the cover just off the bottom of your picture. Note #25 which are the block off plates.
[img alt=https://i.imgur.com/qJ2CbMy.png] i.imgur.com/qJ2CbMy.png [/img]
Last edit: 8 years 10 months ago by Bucko.
