Which valve clearance for best results
  • StanG's Avatar Topic Author
8 years 11 months ago
First some background... The cylinder head is in the shop with brand new valves. The valve seats will be done as well, because of some pitting.
The current shims are 2.30 - 2.40 on Inlet and 2.60 - 2.65 on exhaust.
The manual says: Valve clearance adjustment: Inlet - 0.05~0.15 mm Exhaust - 0.15~0.25 mm.
Based on experience working with these bikes, what is the best clearance one to aim at?
Re: Which valve clearance for best results
My advice, for what it's worth, start at the widest clearance you can on both the intake and exhaust. The valves will seat in to the valve seats. As they do this, the clearances will tighten up. run it in for 50 to 100 miles and then check your clearances again. After this adjustment you should be fine until the next scheduled adjustment period as reccommended in the service manual.
Last edit: 8 years 11 months ago by Kawboy.
Thank you Kawboy.
Time to create page: 0.035 seconds
