Head valve removal/spring compression tool
9 years 3 months ago
I couldn't find searching the forum so here is a direct question.
Internet offers a bunch of spring compression tools, but I just don't know which one would work. Any suggestions?
Re: Head valve removal/spring compression tool
9 years 3 months agoPlease Log in or Create an account to join the conversation.
No eBay APP ID and/or Cert ID defined in Kunena configurationYou will probably be happy with this one.
I modified a 12" C clamp with a machined piece similar to what's on the end of the listed tool above. It's crude but got the job done.
"Necessity is the Mother of Invention"
Hmmmmm Can't Edit the post??? Wasup KZQ???
VALVE SPRING COMPRESSOR PINCER 10" TOOL ENGINE LIFTER SPRINGS RETAINER VALVE - This is what I was trying to add to the post. For some reason it didn't like cutting and pasting the htps line. ???
Kawboy wrote: You will probably be happy with this one.
Yes... I can't find the 'edit' my post as well. I had to rewrite my posts and actually just scrap a few and a bunch of photos and it says I have no access to one of them. That's on the side note.
I will search for the one you suggest. I just spent another hour cleaning the head and I am sooo ready to pull the valves. And just now I was blow drying the head after a shower in hot water.
I might take a 1.5 inch ling piece of pipe and cut it in similar way, then use a clamp. Of course I will update about the progress.
9 years 3 months ago - 9 years 3 months ago
Go for the 'Plunger' style tool, it's way faster than the "C-clamp' method.
www.amazon.ca/Lisle-36050-Keeper-Remover...taller/dp/B0012S61IO
Last edit: 9 years 3 months ago by Bucko.
