Cylinder block base o-rings
- Kwakanuk
9 years 8 months ago
Hey guys,
I'm about to install the cylinder block on crank case. According to partzilla cylinder block diagram it shows o-rings of 67mm and 67.5 mm on the underside of cyl. bl . I do have a set of red o-rings that came with my complete gasket set. The thing is that I can't find anywhere in the service manual any mention of these o-rings. Also I kind of find it a bit odd to install o-ring in that location.
I would appreciate any pointers on that issue.
Thanks
Keep on sixing!
Thanks
Keep on sixing!
Gpz 750 Turbo 1984, Gpz 750 Turbo 1985, KZ 1300 1981.
- LareNurminen
Re: Cylinder block base o-rings
Those O-rings seal the cylinder sleeve (steel) to the cylinder block (aluminium)
If you have not pulled the sleeves there in normally no need for them.
- Kwakanuk
Thanks for the quick response. It makes a lot of sense, now.
Time to create page: 0.048 seconds
