Remove the engine from the frame
- Guido56
9 years 10 months ago - 9 years 10 months ago
Hello guys
I decided to restore to my new Z1300 A3 and I need help.
I have to remove the engine from the chassis, you know if you can 'take off the engine of the A3 without removing the oil pan? The manual talks about but not seen the space seems to me that the oil sump should be removed ..
Thank you
Guido
P.S.
Sorry for my english but I'm using the Google translatorhttp://i.imgur.com/yBn3Sz9.jpghttp://
Thank you
Guido
P.S.
Last edit: 9 years 10 months ago by Guido56.
Re: Remove the engine from the frame
Yes take sump off, easier removal
The following user(s) said Thank You: Guido56
9 years 10 months agoGuido56 wrote: Hello guys
Thank you
Guido
P.S.
This and 'my bike
[img]http://http://i.imgur.com/yBn3Sz9.jpg[/img]
I just thought you might like to know, that even though you are using Google Translator, the translation is pretty good. Your question was completely understandable. I just thought I would post this information so that others on this site know that it is a good tool for helping communicate.
Keep the questions coming. We are here to help.
- Guido56
I removed the oil sump and found this piece of gum inside the tube
i.imgur.com/n468PlE.jpg
i.imgur.com/Yqp78cC.jpg
What function does the valve?
Then I found a small piece of brown color plastic but I lost was about 4mmx5mm thickness of 2mm, what can 'be?
Thanks
Guido
Thanks
Guido
I am pretty sure that valve is the oil pressure relief valve which limits the maximum oil pressure in the system. The hole in the side of the valve is where the excess oil gets dumped back into the oil sump.
The piece that is stuck in the valve, is it plastic or rubber? You are going to have to figure out what it is. It looks like a piece of a square O-ring.
- Guido56
Is rubber
Well I think it's a oring but I wonder how it got there '
