Ticking Noise
- Yaegunp
Re: Ticking Noise
10 years 3 months agokwak1261 wrote: is the spark plug loose ? maybe when it warms up or slight blow on zorst gasket ?
Spark plugs are all tight
1983 Z1300 A5 plus Sidecar.
- Yaegunp
Re: Ticking Noise
10 years 3 months agoMcZed wrote: If it makes the noise at tick-over, try pulling in the clutch to see if it goes away. The clutch on mine is a bit noisy when it's hot.
Noise is still there when you pull the clutch in.
- Yaegunp
Re: Ticking Noise
10 years 3 months agoRickG wrote: Check down under the engine someone may have left a package in plain wraping. :whistle:
No package in plain wrapping either :silly:
- Yaegunp
Re: Ticking Noise
10 years 3 months agokwak1261 wrote: couldnt hear the dog because of that tapping.
sounds to me like its could be missing, how is the compression on the right hand side ?
Compression was good on all cylinders when I checked it earlier this year, I think they all measured around 110 to 130 psi but my memory is not that good. I have done bugger all miles since then.
A reminder to all that the ticking does not occur until it gets up to max operating temperature
Re: Ticking Noise
I hate to be the bearer of potential bad news........but I have had that noise on one of my own 1300's in the past.
I rode the bike with the noise across one summer without issue and stripped the top end over the winter.
It was a snapped valve guide (exhaust on number 5). It had fractured somehow very flush with the hole it sits in inside the cylinder head. You cannot see this until the valve and springs are removed.
This is the reason why it increases when the engine is revved.
Ended up buying a whole used cylinder head with valves and did a swap.
Have a look at this link.
www.kz1300.com/index.php/forum/engines/7...p-end-overhaul-z1300
Last edit: 10 years 3 months ago by strate6.
- Yaegunp
Re: Ticking Noise
10 years 3 months agostrate6 wrote: I hate to be the bearer of potential bad news........but I have had that noise on one of my own 1300's in the past.
Ouch!! :pinch: I have about a hundred questions in my head I'd like to ask right now. But will wait till I can confirm.
Thanks Pete
