New mechanical water seal leaking?
  • charlie9670
  • charlie9670's Avatar Topic Author
Just fitted the new Kawasaki mechanical seal and put the rad on with water and it immediately poured out of the small drain hole which had previously been blocked. All looked ok to me when I put it together and I used white three bond liquid gasket on the mating surfaces. I took it apart and did it again..same result. I'm hoping there is a schoolboy error I've made (which I am prone to) but unsure what it could be. I'll walk away from it for the moment and get the coils and carbs back on. I hope as usual there will be suggestions to what is wrong or what I have done wrong, at least it all comes apart easily now!
:) Z13 UK
Last edit: 10 years 3 months ago by charlie9670.
  • Petez13
  • Petez13's Avatar
Re: New mechanical water seal leaking?
Did you remember to put a new o-ring on the impeller shaft?
  • charlie9670
No :whistle: ..will that let water straight through the middle and into the chamber with the drain hole, if so excellent, there's my schoolboy error..will look for an o ring..Thanks.
:) Z13 UK
  • charlie9670
:cheer: ..Brilliant, thanks Pete, all dry now, too easy to concentrate on the more expensive complicated bits and ovelook the cheap simple bits..easy for me anyway ;) ..the learning curve continues..upwards
:) Z13 UK
  • Petez13
  • Petez13's Avatar
Good I'm glad that sorted it, I've done the job twice and both times successful.
Not always the case with other things I've done on the engine.
Cheers Pete.
The following user(s) said Thank You: charlie9670
  • kwak1261
  • kwak1261's Avatar
its a good job you cleaned out that drain hole... :whistle: :whistle: :whistle:
well spotted Pete
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Last edit: 10 years 3 months ago by kwak1261.
