cam chain tensioner
  • anyoldiron
  • anyoldiron's Avatar Topic Author
cam chain tensioner
10 years 11 months ago
So, im getting ready to breath life into the big Zed, in a previous thread there was a suggestion under what to check, ''cam chain tensioner''.
What should i check and how? Bike has 26000kms on it. All i have done so far is spin it over briefly without the spark plugs in it, no untoward noises.
Cheers
Re: cam chain tensioner
Go check out the FAQ button at the top of the Home page. There's a whole section in there on the "cam chain tensioner" plus a whole lot of other information you should get your head wrapped around. It's a wealth of precious information gathered over the years discussing common issues and common solutions to the issues.
Get your favorite beverage and prepare to engross yourself for a few hours. Well worth the time spent.
  • anyoldiron
Thanks Kawboy, that deals with installing a zx11 tensioner.
What should i do to check the serviceability of the existing tensioner?
Cheers
in a nutshell, if it has an original tensioner, you need to ditch it and get the zx11 tensioner or go to a manual tensioner or modify the original by adding a manual tensioning bolt to the end of it. The stock one WILL crap out and when it does the cam chain jumps a tooth and valves will impact pistons and .................................... poof!!!! You'll be on the side of the road waiting for a Hog rider to pass by with a girlfriend on the back with a sunburn :woohoo:
  • anyoldiron
......................i just had a brain fart, i remembered earlier looking at the motor and thinking that the tensioner looked a little out of place, being black when the rest of the bike motor is not. l took a couple of pictures, it looks suspiciously like the one on my old zx, but then again i have no idea what the original looked like................? Can you tell if this is original or ZX?
Cheers
Last edit: 10 years 11 months ago by anyoldiron.
  • anyoldiron
.............................Oh thats friggin priceless, when cleaning the carbs today, i found one of the mixture screws was put in with loctite, when i got it out i found it had no spring, i think i just found it, look closely at 1st pic LMAO
