CB750 Rings
  • kza13
  • kza13's Avatar Topic Author
CB750 Rings
12 years 11 months ago
I remember seeing something mentioned here about using CB750 rings in the 13, I was looking thru some of my old paperwork on the 13, a lot of it was owned by a mate of mine who passed away from cancer, he bought a 79 model and kept it going for many many years, and he was kind enough to leave me the spare bike and a lot of bits and pieces, anyway in one of the manuals he does mention using CB750 rings, they are 61mm, and a one piece oil ring, so I guess next time I do a re-build i'll buy some of those, checking the prices they are a lot cheaper than 1300 rings even though you have to buy 2 x 4 cylinder kits, cheers all
Re: CB750 Rings
It would be useful to find another bike to use rings from as the 1300 rings are expensive.
My understanding is the standard 1300 had a 62mm bore ?
Is that correct?
  • zoso
  • zoso's Avatar
Re: CB750 Rings
The z1300 definitely has a 62mm bore.
cheers
  • kza13
Re: CB750 Rings
so perhaps he used oversize rings ??, the note didn't mention that, have to check it out some more, no worries, cheers
Re: CB750 Rings
That could well be the case as if he used 4th oversize CB750 rings they would be 1mm larger than 61mm making them 62mm, same size as 1300 standard rings.
  • kza13
Re: CB750 Rings
Yep your right, wonder how prices compare ??
quote from a website:-
Big Bore kits for 750 4's
Nothing replaces displacement but even more displacement
But bear in mind that it's the cam that is the key to an engine's performance characteristics. And, in the quest for power, it's the overall combination of all factors that result in the power output.
Bore (mm) Displacement (cc)
61.00 (stock) 736
61.25 (1st oversize) 742
61.50 (2nd oversize) 749
61.75 (3rd oversize) 755
62.00 (4th oversize) 761
64.00 812
64.50 823
65.00 836
67.00 895
67.50 915
70.00 970
73.00 1060
