RE: GM coil-pack location change
#6375
For those who have looked at this and said NO WAY ! You're correct. There ain't no way the GM coil Pack will fit as described for my re-locating the GM coil to the underside of the OEM coil tray.
That's because about 34 years ago I removed the emissions/smog - Air injection crap from the bike including the complete removal of the reed-housings.
This is why my GM coil pack fit. The height of the cam-cover is the same across it's entire top surface.
34 years was so long ago I had forgotten i had done this.
There appears to be no question/comments so "No Foul- No Points ?
Now, if anyone's interested in how I shaved the cam-cover..........
Last edit: 11 years 8 months ago by scotch.
Time to create page: 0.297 seconds
