new coils
- dmcycles
new coils
12 years 3 months ago
Misplaced my kz1300 manual. which wires do I use for my new accel coils?
Re: new coils
12 years 3 months agodmcycles wrote: Misplaced my kz1300 manual. which wires do I use for my new accel coils?
The green wire goes to the coil for #s 2 & 5
The blue wire goes to the coil for #s 3 & 4
The black wire goes to the coil for #s 1 & 6
Re: new coils
Plus you can download a copy of the manuals on the right hand side of the forum, just thought i'd mention it, cheers.
- dmcycles
Re: new coils
What is the Yellow one for?within the same bunch of wires.
- Craig
Re: new coils
12 years 3 months ago - 12 years 3 months ago
If you're fitting the Accel coils (3 ohm) and you have a ballast resistor - remove the ballast resistor! The yellow wire fed the ballast resistor and 3 pink wires go from that to the coils. Splice in the 3 pink wires to the yellow wire WITHOUT the ballast resistor.
The green wire + 1 x pink wire goes to the coil for #s 2 & 5
The blue wire + 1 x pink wire goes to the coil for #s 3 & 4
The black wire + 1 x pink wire goes to the coil for #s 1 & 6
It does not matter which terminal on each coil the respective wires are connected to as the accel coils fire one plug negative and one plug positive.
Last edit: 12 years 3 months ago by Craig. Reason: Gramma
- dmcycles
