What is this and where does it connect to?
  • Burto
  • Burto's Avatar Topic Author
2 days 4 hours ago
Nearing the end of my total rewire of my 1979 A1 and need to know where this goes, it wasn't connected when I started my full restoration and has no reference on any wiring diagram! its off the rear of the sump but not sure what it does, so if anyone knows.....
Re: What is this and where does it connect to?
2 days 3 hours ago - 2 days 3 hours ago
It's the wiring connector pin for the oil level sensor in the oil pan. Reference page 310 in the Service Manual. Normally has a yellow lead on it. The oil level sensor marries in to the oil pressure sensor and turns on the red oil pressure low light indicator. It can be confusing when the red light comes on because it could mean either low oil pressure or low oil level. In either case you still need to stop the engine and correct the issue.
The system is explained on page 318 in the Service Manual also note the location of the " oil Pressure / Level Warning System" on page 352 in the Service Manual for the location of the "box" that interconnects the wiring for both sensors to the warning light.
Last edit: 2 days 3 hours ago by Kawboy.
The following user(s) said Thank You: KZQ, Burto
