Starting problems / kz1300A
- Perucho
12 years 5 months ago
Hi, I need help with my Z. When trying to start the engine the yellow/blakc wire from the IC igniter starts to burn. Double checked every connection, nothing.. Renew the wire from the battery also.. Igniter dead? Should it be grounded seperately somehow? The frame was repainted..
Turn signals dead too.
- Toddh
Re: Starting problems / kz1300A
Hello Perucho:
You'll need to take a volt/ohm meter and start looking for a dead short somewhere, either in the main harness, a sub harness, or component.
Start with the wiring first, then use the shop manual to verify the pick-up coils, igniter, and ignition coils.
Make sure you do this with the wiring diagram out of the shop manual
Are you blowing fuses?
Regards.
Todd.
Regards.
Todd.
Last edit: 12 years 5 months ago by Toddh.
- Perucho
Hello Todd,
BIG ground problem. Attached picture of the main ground wire. First problem solved, still does not start.
No fuses blowing. I dont have the shop manual..
12 years 5 months agoHi Perucho,
Welcome to KZ1300.COM!
You can down load the service manuals from this site. They're on most pages at the upper right corner.
The following user(s) said Thank You: Perucho
- Toddh
Yup, that ground looks compromised.
T.
T.
- Toddh
On another note, are you sure your side cover switch is in the ON position?
To be on, it must be in the horizontal position.
T.
T.
