How to Repair Instrument Cluster "Glass"
- rdurost
6 years 1 month ago
My 85-MPH speedo has a cracked face. I can make it functional and waterproof easily, but I'd rather replace the glass. What is the least elaborate and expensive way to accomplish this?
Thanks in advance.
Richard
Thanks in advance.
Richard
- englishcw
Re: How to Repair Instrument Cluster "Glass"
6 years 1 month ago
I replaced my broken glass with scratch resistant Polycarbonate . If you make a pattern , about 1/4 inch undersize , a Glazier might be able to cut one out of glass .
- rdurost
6 years 1 month ago
So if I take apart the housing, I can remove the glass from the inside, I assume. It it glued in or clipped in somehow?
- englishcw
6 years 1 month ago
It has been many many Years since I did it , If I remember there is a rubber Gasket . If it had been difficult , or problematic , I would have remembered .
