Another Iridium spark plug question
  • Gunhog63
  • Gunhog63's Avatar Topic Author
7 years 2 months ago
Hi all
Please forgive my ignorance but is it ok to use iridium plugs which I assume have a built in resistance with NGK caps which also have a built in resistance. I have a set of BPR 6EIX. I have new coils that I got off www.z1300.de which tell you not to use the ballast resistor and includes a by pass mini loom to fit in its place. I hope this makes sense.
Any advice greatly appreciated
1980 KZ1300A2
My only fear is that when I die my wife sells my bike for what I have told her I spent on it.
Re: Another Iridium spark plug question
Gunhog63 wrote: Hi all
The ballast resistors are part of the coil input circuit, not the output circuit where the spark plugs are connected.
  • Gunhog63
Hi
Is that a yes or a no?
Cheers
1980 KZ1300A2
Bottom line, the NGK BPR6EIX with the 5K resistor plug caps will be fine. Go ahead and use them together.
The following user(s) said Thank You: scotch, Gunhog63
  • Gunhog63
Hi
Thanks for that. My restoration project has been an 18 month journey of discovery.
Nearing completion now
Cheers
1980 KZ1300A2
