missing spark
- paulb
missing spark
9 years 8 months ago
Hi Guys
i am in the process of trying to get a z1300 up and running, i had it started and running fairly well a couple of weeks ago but when i have tried to start it recently i seem to have lost the spark, i have a spare cdi and tried that but still no joy even using easy start dosnt seem to get any sort of response
any ideas
thanks
any ideas
thanks
- McZed
Re: missing spark
If you haven't already done so, check the coils. The originals are prone to cracking.
Z1300 UK
Re: missing spark
Check switch under seat, has to be horizontal, kill switch short, clutch safety switch, main ignition on and tell tales working?, fuses, power to coils ??, usual stuff
- paulb
Re: missing spark
Hi
i have power so assume its not to do with the kill switch or the power switch beneath the side panel, also i have no spark anywhere so if it were a coil i assume it would fire on the other cylinders
- stocktoy
Re: missing spark
if you have a 79 it maybe the pickups on the timing advancer they were a weak point on the 79's I understand.
Are you getting a pulse signal when you crank it over?
