Starting Problem 1300 z Kawa A2 80 MODEL? HELPNEED
  • jacobs
  • jacobs's Avatar Topic Author
10 years 11 months ago
#9960
Is there anyway of testing the resistors on the starting circuit and what should the Ohm reading be? Why is these resistors necessary in the coil circuit?
How do I measure the starter coils and the measurements of the Pickup Coils/?
Can anybody tell me where I can find the Condensor or capasitor on this bike for the fire or does the Pickup Coils generate the spark for ignition?
  • kza13
  • kza13's Avatar
Re: Starting Problem 1300 z Kawa A2 80 MODEL? HELPNEED
#9978
You can download the workshop manual from this site, it'll have most of the info you need
Check the home page of this site. They're on the lower right.
Last edit: 10 years 11 months ago by kza13.
The following user(s) said Thank You: jacobs
  • Tyler
  • Tyler's Avatar
#9982
You have pickup coils on the right hand side of the engine, an igniter module, and three coils with a ballasting resistor. All of these components must be in perfect shape order to work. The factory manual covers the ignition in detail, you will need to review it and use the test procedures in the ignition section. You can download the manual on the home page of this site if have not already done so.
Is your ignition completely dead, or is it just one pair of cylinders?
1981 KZ1300
