Ignition Coil Removal
  • Yaegunp
11 years 1 month ago
#9141
Been searching and cannot find any info. In order to remove the ignition coils do I have to remove the top radiator hose aS well? Or am I missing something?
1983 Z1300 A5 plus Sidecar.
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Ignition Coil Removal
#9142
I don't think so.
First remove the lower two coils by removing the two nuts on the top side of the coil mounting plate (two either side of the upper coil - under the mountain of wiring).
Then remove the two nuts for the upper coil from the underside of the plate.
  • Lucien-Harpress
  • Lucien-Harpress's Avatar
#9144
Due to the wiring harness, I have to start from the left and work my way right- as you pull each coil, it will open up access to the bolts on the next one. You can pull the wires off once the coils are removed.
  • Yaegunp
#9145
Ahh yes that will work I think. Because of the sidecar I was working from the right hand side and from there it meant removing the radiator so you could remove the top hose. There was no way I was getting that right hand side off without doing that, which seemed a little odd to me (pita).
The further I go the more it seems I might have to remove the sidecar;(
  • kza13
  • kza13's Avatar
#9154
Damn take the chair off !!!, easy with mine, I dread thinking of you trying to take yours off, might be ok if all the lines have connections, good luck, try and do it with the chair on :-)
  • Yaegunp
#9156
Yaegunp wrote: Ahh yes that will work I think. Because of the sidecar I was working from the right hand side and from there it meant removing the radiator so you could remove the top hose. There was no way I was getting that right hand side off without doing that, which seemed a little odd to me (pita).
A couple of 'bugger this!!' stress moments and 'walk off the job' moments but I got them out eventually. I am learning soooo much and it feels good that I may some day be the master of my own destiny in terms of the Z1300. Hey Pete, I was a poofteenth off taking the sidecar off but after some considered checking of wires I realised they don't all have connections so I persevered with it still connected. Though I might have to go and see my osteopath sooner rather than later :pinch:.
Making the sidecar easier to remove will be another project in itself, I have done preliminary investigations and to do it properly will take some time and effort. I am reluctant to go too deep into the project so as to avoid drowning in information and loose parts all over the place :unsure: (organised of course), so I'm concentrating my efforts on remembering charging systems, ignition systems and carburetors right now.
Time to create page: 0.129 seconds
