Coil mounting
  • Mikez
  • Mikez's Avatar Topic Author
Coil mounting
12 years 11 months ago
#595
I've got a question regarding how the original coils were mounted. When I got my bike earlier this year it already had GM coils and extra ballast resistors in it and I intend to mount some AW82-TRI coils soon. I just ordered a set from a bike breaker in Virginia :). Since the fiche and diagrams appear to be spotty on the subject, how are the original coils mounted on the bike? Were there brackets and bolts? Or do they bolt directly onto the frame? My bike appears to be missing all the hardware from the originals and I'm going to have to look at replacing it or mounting elsewhere. Thanks!
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Coil mounting
#596
Golly Mike I don't remember how they perzactly mounted. I do know that one goes up between the frame tubes and the other two are strategically so that they must be removed to access the valve cover. :S
Sorry I couldn't offer more. I'm sure someone will come along soon with the information you need.
  • Mikez
Re: Coil mounting
#597
Thanks Bill!
On pg 49 of the manual all it says is to remove the nuts so I think it bolts directly in.
So unless someone else knows more it looks like those nuts and bolts are all I need. I don't have the originals, though, and the ones pictured look pretty specific.
Ebay searches came up dry. Would anyone happen to have a pair of these lying around? I'm sure someone that has done a GM coil swap or coil relocation has some. I'd be willing to pay for them through PayPal if needed :).
  • zoso
  • zoso's Avatar
Re: Coil mounting
#598
Mike
The original coils bolt directly on to the frame - there are no mounting brackets. There's not a hell of a lot of room though - they're very tightly packed in !!
Let me know if you need more info and I'll take a photo of them tomorrow and post it on here.
Cheers.
The following user(s) said Thank You: Mikez
  • Mikez
Re: Coil mounting
#599
That's pretty much the verification I was looking for. Thanks!
  • Metric_454
  • Metric_454's Avatar
Re: Coil mounting
#600
I'll take a picture, as mine were just recently separated and post it to help.
One picture shows the diagram for the coils. Notice the standoffs? Hexagon shaped pieces that space the coils from the plate in the headstock.
Thread rods extend through the plate (4) upwards and (2) downwards to mount the three coils with nuts.
The coil side of the stand-offs are mounted with Phillips (star) screws I believe.
Red circled holes are for the coils that hang upside down, yellow are for the one coil mounted on top.
Hope this helps
No matter where you go, there you are.
Last edit: 12 years 11 months ago by Metric_454.
Time to create page: 0.243 seconds
