Lost Spark after pressure washing
  • kz1300texas
  • kz1300texas's Avatar Topic Author
#7651
Just picked up an 82 kz1300, drove it 80 miles home. bike was filthy. I mean just filthy. So I gunked her down and pressure washed with seat and tank off. Dried it best I could with the air hose. Now I have no spark. (pulled plug to check) I checked all the wiring and nothing looks out of place. What cold I have done to it? Turns over, everything else works.
Last edit: 11 years 4 months ago by kz1300texas.
Re: Lost Spark after pressure washing
#7652
My best suggestion would be to have a look at the coils. These bikes are notorious for cracked coils. If nothing else remove the coils and check for cracks on the barrel of the coil. I'm in the middle of a major restoration and I found cracks on 2 of the 3 coils about 3" long and 1/8" wide. Needless to say they've been replaced.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
#7658
kz1300texas wrote: Just picked up an 82 kz1300, drove it 80 miles home. bike was filthy. I mean just filthy. So I gunked her down and pressure washed with seat and tank off. Dried it best I could with the air hose. Now I have no spark. (pulled plug to check) I checked all the wiring and nothing looks out of place. What cold I have done to it? Turns over, everything else works.
First off: Welcome to KZ1300.COM!
Secondly: Don't pressure wash motorcycles. You'll drive water into every crevice. If you don't short out something, as you probably did, you will most assuredly cause long term corrosion where you least want it.
  • kz1300texas
#7659
I thought it was odd I lost spark on all cylinders but will remove them and check..
Thank you
G
  • kz1300texas
#7660
Bike is going to be completely disassembled and restored. just wanted to clean it up a bit.
  • AERIAL0
  • AERIAL0's Avatar
#7661
Welcome to one of the best forums for the Z1300. Take a gander at the FAQ section, a great source of info. And plenty of advice from members who are willing to help.
Re the jet wash :woohoo: its a no no. All the best with your restoration and add photo's please.
