Pingel Fuel Tap unexpected issue ??
- Tonto
12 years 3 months ago
Guys,I gave up on the seized original fitment Fuel Tap on my A1 and today attempted to fit a replacement Pingel unit: the recommended A1702C adaptor, and Tap 6211C - both look well manufactured.
Adaptor fitted spot on, but the upper part of the tap filter element will not fit through the hole in my tank :ohmy: and appears that the existing cut out in my tank will need shaving by a couple of mm to accommodate the tap/filter. I'll get around to this when its Winter and I do a few minor planned tweaks to my bike.
Not sure why this is ?? My bike is fitted with the standard large tank ?? I assumed the large tank was identical throughout the production run.
Any clues - Cheers Tim
Re: Pingel Fuel Tap unexpected issue ??
Hmmm .. same sort of problem I had with that K&N air filter going into the airbox hole, perhaps the company will say that the tank has "either shrunk or warped" over the years
, sorry couldn't resist, contact Pingel and let them know, always handy to tell someone that what they make doesn't work, cheers
- zed_thirteen
If I remember correctly you do need to drill/file a rounded hole for the pingel to fit through.
I think I masked the hole, put the adapter on, and then marked the area that needed to be removed.
It's not a direct bolt on - it does need some modification
- Craig
Zed Thirteen is correct, I have recently fitted one. Marked out the tank with the adaptor plate in place and then used a round file inverted into the tank so most of the metal filings ended up outside. I then blew it out with compressed air. All good!
- Tonto
Thanks for the clarity guys - I guess the next crappy spell of weather, I'll be attacking my tank ! :ohmy:
Cheers Tim
Cheers Tim
