Q. -What do you get when you cross a B.B.Q. with a spark-plug?
6 months 2 weeks ago
#34687
Answer: "Scotchs Color-it-Tuned" !
A spark-plug and a BBQ ignitor electrode
The two, assembled
With an extension
Showing transparency
Couldn't get a great picture but when installed and with the naked eye, it works brilliantly
  • stocktoy
  • stocktoy's Avatar
Re: Q. -What do you get when you cross a B.B.Q. with a spark-plug?
#34691
Interesting
  • dcarver220b's Avatar
#34696
How did you connect the igniter to the plug base? Expoxy?
6 months 2 weeks ago - 6 months 2 weeks ago
#34698
Start by breaking 0ff the ceramic.
Grind off the rolled edge
Punch-out the remaining ceramic
To increase the viewing area, drill out to 13/32"
A 7/8" hole saw cuts the 1/2" thick Lexan lens and also leaves a center-hole. Use a nut/bolt as a mandrel so the lens can be mounted in a drill-press
Use a coarse file to turn-down the "lens"
Use a FINE file to get the final diameter to within several thou.
Apply "crazy glue" to the inner bore and press the lens into the body
The hole saw center-hole is typically 1/4". Depending on the diameter of the ceramic, enlarge the center-hole if required.
The fit should be as close/snug as possible.  Trying to press the ceramic into a hole too tight may break the ceramic !
Use crazy-glue or epoxy to secure the ceramic.  Note: If using crazy-glue, position the ceramic first !
Epoxy allows for positioning and adjusting !
The final depth of the electrode is somewhat arbitrary. The following is what was chosen.  A "Gunson's" is shown for comparison.
The spark-plug end of the wire electrode (on the spark-plug used) comes flattened and folded over.  Keep this feature !
Wrap the entire length, including the folded end,  with fine wire
The finished winding diameter at the fold-over, must allow the terminal-end to thread on.
Slide a piece of plastic tubing over the wire-wound electrode. This is merely for "build-up".
A piece of woven insulation is then added.
Shrink-tubing is the final layer.
The wire electrode is S/S so can not be soldered !
After the insulation/shrink-tubing has been applied and after the terminal end has been threaded on; put a few drops of crazy glue into the open end of the terminal to secure it to the wire wound electrode.
Final note: The lens material in a "Gunson" is unknown. The "Gunson" instructions infer their lens is a synthetic material.
The same caution therefore applies to this project.
Last edit: 6 months 2 weeks ago by scotch.
The following user(s) said Thank You: KZQ, zed_thirteen, stocktoy
#34701
You have mad skills, Sir Scotch!
Time to create page: 0.223 seconds
