Some off the wall stuff.
7 months 2 weeks ago - 7 months 2 weeks ago
I was poking around in the old FAQ and I came upon this:
"Another good tip is after you've bled the brakes as best you can, tie the lever hard back against the throttle grip with a cable tie & leave overnight. In the morning you'll have absolutely no air in the system. Don't ask me how or why it works, a bike mechanic friend told me about it years ago.
Phil S."
OK Phil I'll give it a try.
Phil S."
Last edit: 7 months 2 weeks ago by KZQ.
Re: Some off the wall stuff.
Sometimes yes. Sometimes no. Depends where the air bubbles are trapped.
I've done this before when I had time...
Also helps to tap the calipers and brake lines with a 10 mm wrench. 10 mm only!
Time to create page: 0.136 seconds
