Been Away
Been Away
2 years 5 months ago
Musings.. been away. Work. 4 letter word. Living away from home sucks. 75 hours per week leaves no KZ1300 time, even forum time.
Buggings...... why can't I get my coils to spark on the bench? Apply 12 vd to primary, switch to simulate points, plug grounded, hi volts to secondary terminal and no spark on all my coils? Buggers. No time to check.
Time conundrum.. I'm too old for this shit.
That is all.
That is all.
Re: Been Away
I would test the primary and secondary of the coil with your ohm meter for a start.
You are putting some hours in at work, aren’t you? I thought you were only going back for a short stint, but that was months ago. There comes a time when we all have to slow down a little. I guess the paycheck is too good to resist in your case.
Re: Been Away
2 years 4 months agoWill test more when the OT ends.. but initial testing across primary and secondary was good, in spec.I would test the primary and secondary of the coil with your ohm meter for a start.
...and yep, this is my LAST gig!
D
