Starting Motor Clutch Query
  • Tonto
  • Tonto's Avatar Topic Author
Re: Starting Motor Clutch Query
12 years 4 months ago
#3563
Well, I got so fed up with constant niggles, I chickened out and bought another Starter Clutch / Sub Rotor assy complete, off evilBay, for a bargain. I fitted it today and she works perfectly :cheer: :cheer: :cheer:
But I do have one last silly question: anyone any thoughts ?
If I torque up to the specified 94lb/ft., my reduction gear no longer has free movement and will not turn; almost as of its stuck to the crank ??
But if I remove the thin spacer (0.3mm I think) that sits betweem the starter clutch unit and reduction gear, I get full movement at full torgue setting, and a fully functioning assembly.
Not sure why, or if I dare ditch the thin spacer ?
Finally starting to hope I might get to run her this Summer :woohoo:
Cheers Tim
  • Toddh
  • Toddh's Avatar
#3564
Hello Tim:
Is the replacement Clutch the same as your old one?
What year is your bike?
Take a look at the illustrated parts breakdown per your year and model and do a comparison for order of installation.
Can you tell if the engine cover was ever changed? Are there any obstructions in the engine case or engine cover pin sockets?
Regards.
T
  • Tonto
#3566
Todd, hi
My bike is a 1979 A1 model, from engine and frame numbers, it appears to be a very early production run (one of the first 400 made: probably before they fixed all the gremlins :) )
The replacement starter clutch and sub-rotor assembly is an exact match for my old unit, and from the parts diagrams / illustrations I have (for the initial US 1979 A1) all does seem as it should be.
Re the engine cover; again all looks as it should (albeit, its been retro chromed) with no obstructions.
Cheers Tim
  • Toddh
  • Toddh's Avatar
#3567
When you say Sub-Rotor, is yours fitted with the second stator on the Left?
You may have done this, but take the rotor back off and see if the starter clutch gear free-wheels, without that rotor installed.
Take it one step at a time as you assemble the clutch, to see if you can determine what is causing that gear to not freewheel.
Not a good thing if it doesn't freewheel, bad for the starter.
T.
