Starting Motor Clutch Query
  • Tonto
  • Tonto's Avatar Topic Author
12 years 7 months ago
#2107
Guys, I recently bought my Z13 from a genuine previous owner: he told me that the bike had developed a starting problem a few weeks earlier and that a Starting Motor Clutch repair kit had been fitted: I have the invoice to show work done.
But cut forward 3 weeks and my Zed will not start; sounds like the gear wheels are slipping on the starting motor - bugger :angry: :angry:
Can anyone confirm if this is this a known fault with the Z13 (or just my misfortune), and importantly; is it an easy fix.
Any advice greatly appreciated. Cheers Tim
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Starting Motor Clutch Query
#2108
Starter clutches are troublesome on these old Kaws. Fortunately the repair on the 1300 is not difficult. It's not a bad idea to check the starter but your description sounds as if your starter clutch is slipping. If you review the section on the starter in the FAQ you'll find a pretty good description of the clutch. There is one inaccuracy in the FAQ: The springs do push the rollers against the boss but it's really the ramp design that provides the grip. Once the engine spins up the rollers are pulled back by centripetal acceleration compressing the springs. Most of the time replacing the rollers, springs and the cups is sufficient to get the clutch working again.
Best of luck.
Last edit: 12 years 7 months ago by KZQ.
  • Tonto
#2109
Thanks for the advice: I'll have a shot at it this weekend, fingers crossed she'll soon be back in working order.
Cheers Tim
  • Toddh
  • Toddh's Avatar
#2111
Tim:
I just did my starter clutch a couple of weeks ago. Like Bill states, changing the roller and springs usually takes care of this problem. I would like to add the following.
a: Carefully inspect the heavy metal clutch housing. These have a tendency to crack and fracture (worst case scenario) I always take my clutch housing to a local machine shop and have them magna-flux to check for any unseen cracks. If it's cracked, the clutch housing can expand (While under a load) and in turn cause the rollers to not grip the reduction gear. Are the roller pockets damaged or show any unusual wear? It's ok to have some light wear marks from use, but no galling or gouges in the roller pocket. With the springs, pin, and roller in place, does it glide smoothly in and out of the pin bore? Are all of the machine surfaces getting engine oil lubrication?
b: is the bearing surface(roller surface) on the reduction gear damaged?
c: Are all of the parts installed correctly? As you disassemble the starter clutch, have a copy of the parts breakdown from the microfiche with you. This way you can see if the person who re-assembled the clutch last time, did it in the right sequence. In years past, I have seen missing thrust washers and spacers. Also the thick thrust washer between the case half and reduction gear has a chamfered edge. the chamfer side faces the engine.
d: if you have a Sub Alternator, while you are in behind the engine cover, Ohm out the Stator and repair as needed.
Parts for a light rebuild. All prices are list, and are available through Kaw. or through other after market suppliers like Z1 Enterprises.
92122-004 roller X3 6.62ea
92081-110 spring X3 3.22ea
92043-087 pin X3 5.32ea
11009-1090 gasket X1 11.94ea
TOP OFF OIL LEVEL
It helps to surgically clean the gasket material off of the case half and engine cover. Also use black RTV (Silicone) on the rubber stator cover grommet. Make sure you get all of the old silicone off before reassembling.
Regards.
  • Tonto
#2117
Todd, thanks for this: I will be having a go at the weekend and your observations will be really helpful.
I know the bike had an issue and a supposed fix about 4 weesk ago, so I am hoping its a case of incorrect re-fit at that time: fingers crossed, but guess I will find out soon.
Cheers Tim
  • Tonto
Re: Starting Motor Clutch - Nightmare continues !
12 years 6 months ago - 12 years 5 months ago
#2958
I thought I had fixed my Zed's Starter Clutch woes: on strip down the initial problem was that the three retaining screws had all worked very loose ! so re-fitted everything, re-torqued etc: but did think the thrust washer was thin and insignificant. But, she has fired up every day for the past 2 weeks two weeks :cheer:
But alas, today on start up there was an intermittent and familiar slipping noise, coming from the starter clutch - Bugger :angry: - but she did start a few times.
But, I keep thinking about that poxy Thrust Washer: today I checked Kawasaki part microfiche lists, it states the washer should be 2.3mm thick: has anyone had issues with the thrust washer or can reccomend a source for a replacement, as they appear to be No Longer Available.
Cheers Tim
Last edit: 12 years 5 months ago by Tonto.
