Short Legged ?
Re: Short Legged ?
7 years 8 months ago
#22728
For what its worth.................I was born with the legs of a Jack Russell rather than a Greyhound and have owned over 10 x Z and KZ1300's since the early 80's.
I can honestly say I have never found the seat height and issue at all, its just managing the overall weight of the bike you need to concentrate on.........no matter what height or build you are !
The seat height maybe around 32 inches with nobody sitting on the bike, but by the time you allow for a bit of "sag" the suspension will have, then the seat foam crushing down when you sit on it, then your own body weight ..............you are probably nearer 30 inches once on the bike.
Not a problem !
UK.
  • trainers
  • trainers's Avatar Topic Author
Re: Short Legged ?
#22731
How tall are you for curiosity ?
Re: Short Legged ?
#22732
I realize this is a work in progress but: Does anyone else see a potentially serious structural flaw with this frame mod?
  • Frank833
  • Frank833's Avatar
Re: Short Legged ?
#22740
scotch wrote: I realize this is a work in progress but: Does anyone else see a potentially serious structural flaw with this frame mod?
I have two concerns.
1) those new bars will have clearance issues with battery and what not. You will have to address that (and side cover mounts).
2) the weight of the rear of the bike is mostly supported by the shocks. The bars you are removing tie into the “gusseted” frame area. The bars you are adding in tie in below that area. The area between the new bars and the gusseted area will flex (and break). At the very least, the “gusset” that the shocks mount to should be extended below your new bars.
Yes, that bracket is not really a gusset, but not sure exactly what we should call it.
Last edit: 7 years 8 months ago by Frank833.
Re: Short Legged ?
#22744
It actually is a gusset - It just doubles as a shock mount.
Better to discover this now then after the bike is completed and you soon realize that you no longer require a center-stand or side-stand to keep the bike up.!
That first bump in the road would be really[strike] interesting[/strike] terrifying !
Last edit: 7 years 8 months ago by scotch.
  • McBoney
  • McBoney's Avatar
Re: Short Legged ?
#22764
Thanks gents, exactly the reason why it is a mock up and posted here before I cut the frame!
The battery will be a slimline lithium one (like this: www.antigravitybatteries-uk.co.uk ) and dropped below where the centre stand bottom legs go. The side covers will be either not there at all or custom made ones to fit the gap.
I did look at the gusset. I was planning to weld a triangular 'gusset tab' at the top of the new bars to the existing uprights as well as using a new gusset tab (half moon shape) to go from below the new connection to just over it - and that one will have the shock mount. That should give it enough strength. Ride height should remain the same.
However, I do realise I have missed something.... the ride height in an empty frame is quite different from that with the engine in etc... so I will no do anything until I have the engine in. It may be that with the engine in and the thinner seat, the ride height is OK for me, in which case not cutting required.
AND in any case I still have to get my structural welder to look at this plan, so it will be a while before I execute this plan, but please do keep your concerns coming so I don't miss anything.
Cheers
Last edit: 7 years 8 months ago by McBoney.
Time to create page: 0.144 seconds
