Z1300 Service Manual (with Bookmarks)
  • Yaegunp
10 years 2 days ago - 10 years 2 days ago
#14471
For some time now I have wanted to setup our manual with Bookmarks as opposed to hyperlinks and I have finally found the time to do it. The manual still has the hyperlinks but I personally find it much easier to use bookmarks to navigate through the manual.
For those who are uninitiated to bookmarks I will endeavor to make some sense of them for you. If you have never seen a bookmark then that is probably because you have had them switched off in your PDF reader of choice. When switched on they normally display down the left hand side of the page where you can click on them to take you to your area of interest.
Below I have included a link to the service manual with bookmarks, remember you can download it to your computer and only then will you be able to see the bookmarks. Hope it helps.
Z1300 Service Manual with Bookmarks
On another side note, you can navigate to any page you want in a pdf document by typing the page number in the page number display.
1983 Z1300 A5 plus Sidecar.
Last edit: 10 years 2 days ago by Yaegunp.
The following user(s) said Thank You: Soulinaearthsuit, Raygun, pauljt56
