IT LIVES!!!!
  • anyoldiron
  • anyoldiron's Avatar Topic Author
IT LIVES!!!!
10 years 9 months ago
#10255
So i got the monster running, no leaks anywhere, revs freely and sounds great (except at idle, popping a bit, hopefully that will disappear when carbs synced properly).
Video to follow, thanks for all your help Guys!
Cheers
  • anyoldiron
Re: IT LIVES!!!!
#10280
Just as i got it running about right the throttle return cable snapped, but i synced them anyway. Still have some work to do, but very happy with the progress
  • Yaegunp
  • Yaegunp's Avatar
Re: IT LIVES!!!!
#10282
Sounding nice B) Congrats on getting her up and running
1983 Z1300 A5 plus Sidecar.
  • caddypat
  • caddypat's Avatar
Re: IT LIVES!!!!
#10289
that sounds good,do the older engines make more noise than the injected ones? mine is an 86 and it seems quieter. just curious. pat
  • anyoldiron
Re: IT LIVES!!!!
#10290
caddypat wrote: that sounds good,do the older engines make more noise than the injected ones? mine is an 86 and it seems quieter. just curious. pat
No idea, but its inside a 16'x16' room 9with the door open0, so theres probably a lot of amplification.
Re: IT LIVES!!!!
10 years 9 months ago - 10 years 9 months ago
#10294
Just a thought for those who have made up your own gauge sets. I've seen a few videos showing the bike running and the video is looking at the gauges. You can see a lot of needle flutter on the gauges and of course you're synchronizing the carbs so the flutter is at equal points on your gauges. If you take your set up and add 1/8" needle valves in the vacuum lines before the gauges , you can throttle the vacuum to each gauge and get the flutter down to near nothing. It's better for the gauges and simplifies determining what you see and helps you dial in your adjustments. The old gauge set that used to be available for the CBX (6 gauges) had these valves. Just food for thought.
Last edit: 10 years 9 months ago by Kawboy.
