1979 Carb Rebuild (Pt 1)
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: 1979 Carb Rebuild (Pt 1)
13 hours 23 minutes ago
Caps for the 6 pilot screws are not required. 3 to 3.5 turns is the generally accepted starting point for the pilot screws. A "Color-Tune" can dial them in but I've found that the "Blue" range is relatively broad, so some time is required to find a middle point.
Six Years ! What, arise from the dead you old thread.
Hi Scotch,
Would you please share your tool used to adjust the pilot screw for cylinder # 3 ?
Thanks in Advance
11 hours 59 minutes ago - 7 hours 43 minutes ago
"Idle-air screw conversion"
Last edit: 7 hours 43 minutes ago by scotch.
