1979 Carb Rebuild (Pt 1)
- Mightyzod
- Haggler
Re: 1979 Carb Rebuild (Pt 1)
9 years 10 months ago
Great article, very informative thank you for taking the time to post
- Dion
9 years 5 months ago
Hi Scotch
very informative,
i used a watered down degreaser of which i tried a sample inside the diaphragm cap, looked great
as i had been boiling the carbs, i thought why don't i just add some to the boiling water!, Dah bad idea, especially as i did not work out the ratios water/degreaser
sent the center body/cap/bowl BLACK, what a mess took ages to get the black greasy substance off, which left them looking rather magnesium in appearance
you can see the center bowl in pic, i then at Robs suggestion took it to a powder coater, who dipped it in their solution, lot better but not what it was, will be pulling apart again when i get my second lot of stainless screws(lost first)
also soaked in thinners for 12 hrs after boiling just to make sure, these carbs had been abused and where in a mess
i have question im not sure if some how i have missed something in the cleaning!, fitted up to find
1, leak from bowls drain, figured it as the drain screws on 2 not sealing,! so put all three through my lathe (Dewalt battery hand held type) file first then 600 wet/dry beautiful .
2 i hooked up Robs vacum gauges to balance carbs, Rob was unable to effect change on the center carbs regards to balancing.
outside ones ok, any one come across this before, carbs where completely dismantled and complete kit put in,
im running no air box standard pipes presently, will probably have to jet up slightly but that is not the problem, bike revs nice but carbs cough
have not fitted up your floats yet,do you or anyone have a measurement for standard float height please?
the alloy bar is 20mmX4.3 thats all i could get is why!
still a lot lighter than original and looks wholly better
Dion
very informative,
Dion
9 years 5 months ago - 10 months 1 week ago
The only way to set the Brass Floats is the "wet" method. RE: Sync'ing carbs. It's important to have the Choke/Fast idle static adjustment done first to ensure the throttles are closing near the required measure. The synchronization will fine-tune this setting. There should be a tiny bit of slack in the throttle cable with throttles closed on the idle adjustment screw, with no choke. With FULL choke the throttle plates should close to the IDLE position ! I've found that setting the throttle plates statically prior to installation, makes the sync'ing easier. A piece of .006" brass shim stock 1/8" to 3/16" wide and about 4" long. Open the throttles and insert the strip in the venturi and allow the throttles to close on it. Adjust the sync screw so the throttle-plates close on it. Use a strong source of light from the opposite side of the venturi's to see the gap. If you've pre-adjusted correctly, only a very slight resistance to pull the strip out, is required. Lightly "snug" the lock nuts and reinstall on engine. Sync as required. It takes VERY little adjustment on the sync. screw to effect a vacuum change. With every adjustment "snug" the adjusted locking nut. It's not uncommon to go back and forth a number of times to get the 3 carbs equal. If the engine RPM is slow to return to idle (or does not at all) you may have one or more of the sync adjusting screws turned IN to it's limit. In other words - The compression spring in the adjuster link has been compressed tight and this causes the ball-joint(s) to bind. This will make sync'ing impossible.
RE: Jetting - DON'T ! Not until you have the carbs sync'd, the idle mixture adjusted ( Color-Tune or by ear) and you've put some miles on the adjustments. Arbitrarily re-jetting before you know for a fact that everything else is operating to spec is a waste of time and money and is NOT a cure for poor adjustments. I've stated this repeatedly: I've rebuilt many sets and always run them on my bike before selling. I've NEVER had to change jetting !!!!!!!!!. The carbs are very forgiving in terms of air-filter/air intake systems. I have a DG header and a custom intake with a K&N Oiled-filter and run stock jetting. I have the main-needles in the #3 slot. I've tried Leaner by one slot respectively and had to return to the #3 slot. The plugs burn "Tan" and clean!
Last edit: 10 months 1 week ago by scotch.
The following user(s) said Thank You: zed_thirteen, Dion, PaulD
- tackelhappy
"as i had been boiling the carbs, i thought why don't i just add some to the boiling water!, Dah bad idea, especially as i did not work out the ratios water/degreaser
you can see the center bowl in pic, i then at Robs suggestion took it to a powder coater, who dipped it in their solution, lot better but not what it was, will be pulling apart again when i get my second lot of stainless screws(lost first)"
Not that this friend of mine can help you much in view of the distance between you two, but the photo's may help you find a way of cleaning the outside of those carbs.
He does vapour honing, - a slurry of fine glass beads and water inside a sandblast cabinet, as well as soda blasting.
www.tophrestorations.ca/latest.html
The following user(s) said Thank You: Dion
Well you're not the first and probably not the last to boil a set of carbs in a " favorite concoction" and get into trouble. Hot acid or hot caustics are a lot more aggressive.
Vapor blasting is a form of surface cleaning using chips of frozen carbondioxide gas. The chips are not very aggressive and the byproduct of this type of cleaning is the material being removed and carbondioxide gas. The only issue here is the specialized equipment needed so it's not a do it yourself project.
Soda blasting is slightly more aggressive and setting up for sodablasting is relatively cheap. The sodablasting media is also fairly cheap. The only issue here is the sodablasting media is a one shot deal. Once used it's done so a lot more waste involved.
Either way you can get the outer surfaces cleaned up. The problem I see is what happened inside all of the circuit passages. Some of those passages are super small. I'm concerned that you won't be able to get them cleaned up.
