Flat spot
- McZed
Flat spot
12 years 3 weeks ago
Hi guys, me again, and I know I’m a pain in the butt.
The bike is running reasonably well, over 3000 revs it goes like a train, really responsive to the throttle.
The problem I have now is at tick over it’s a bit lumpy, and I need to keep blipping the throttle, unless I have the tickover above 1000 revs. When I’m riding it there seems to be a flat spot between 2500 revs and 3000 revs, after that it goes great.
I have balanced the carbs, and colour tuned them to Bunsen blue. If I take a spark plug out it’s a nice light straw colour. I have the main needles set to the middle position, would raising, or lowering them make any difference?
Z1300 UK
Re: Flat spot
Hi McZed,
Where do you have your idle screws set? I'd start at 3.5 turns. Before I was satisfied with my set up I had my idle screws at 5 turns and the needle jets in the third notch. Mike at DG Performance told me to lower the needle jet a notch (raise the needle) and reset the idle jet to 3.5 turns. His advice got me going in the right direction.
I ended up with 96 mains, 3.5 turns on the idle screw and the circlip in the sixth notch, which works for me till I get back into the carbs again. When I do, I'll up the mains to 100's and return the circlip to the third notch.
Best of luck.
Best of luck.
