Carbie assembly cleaning
  • Torque59
12 years 11 months ago
#317
Hey again guys,
As you guys will be aware I am in the process of overhauling my A4 carbies.I have pulled them apart and am wanting to clean the carbie tops, bowls and bodies up. Initially I was going to take them to get aqua blasted but because I am a tight a@#& I thought that I would see if anyone out there in Z13land had a homemade receipe to soak the carbs to clean them up nicely. I have seen on the net if you soak your carb assembly in a mix of Pine-Sol and water left over night works well. Unfortunately here downunder we don't have this product. So if anyone can assist that would be awesome. If the worst comes to the worst then I'll just have to get them aqua blasted. Thanks again
Re: Carbie assembly cleaning
#318
Honestly mate just use diesel.
Leave them in for a few day & move them around now & then.
Diesel does not spoil or affect alloy but has strong detergents in it that remove all scale & carbon.
I leave my whole carb bodies in it & then come out spotless.
Pete
The following user(s) said Thank You: Torque59
  • zoso
  • zoso's Avatar
#321
Pete
Once the carbs have soaked in diesel what do you use to dry/clean the excess off ?
Billy
#324
Billy,
I just use WD40 or petrol if you have some, just rinse with that.
I did use to buy 5 litres of celulose thinners to bath them in, but found it created a bit of acidation sometimes & left a deposit, but diesel being a light oil does not do that.
Its best to leave them a week or so if possible. The results are great.
Pete
  • zoso
  • zoso's Avatar
#325
Cheers Pete - think I give that a go in the winter. Will be interesting to see the results using diesel. I've used diesel to clean chains but didn't cross my mind to use it for the carbs.
Billy
  • Torque59
#335
Thanks Pete I appreciate you taking the time to reply.
Cheers
T.J
