What would cause cylinder 1 to be dead but 2 - 6 are good?
5 months 4 days ago - 5 months 3 days ago
#34759
2026-05-11 Chocolatie Dead #1 Cylinder
I had noticed that the left-hand side muffler had uneven pulses as compared to the right hand side. Occasional back firing, popping.Thought it was the OEM carburetor that Herb contaminated with particulate rust after using vinegar in the tank and not installing a fuel filter.
So I installed a carburetor rack I had rebuilt and the bike runs the same. Unlikely it's a carburetor issue.
Compression, Fuel, Ignition. Simple. Right?
Started with a compression check.
Here are the results.This is with the throttle closed. Cylinders 1, 2 and 3 used motorcycle battery alone and cranking got to be a little slow.
Put a 10 amp charger on the battery to measure cylinders four, five, six. Units are PSIG.
135
120
120
130
120
120
That's 11.1% delta when 10% is great. Close enough given battery condition and closed butterflies.
Measured the ballast resistors. Units are Ohms. 1.7 Ohms all three.
  • Plug one is sparking when grounded externally
  • Checked plug 1 cap resistance ~4.5k Ohms
  • Cut plug one wire back 5mm and check from bare wire to ground - strong spark
  • Reconnected cap - spark about the same as other plugs (daylight reading)
  • Run engine - still missing on cyl 1
  • Used ColorTune - no fire in 1. Cylinder 6 looks great - nice and blue
  • Sprayed WD-40 into the inlet port that connects to the manometer and she instantly had combustion - so cylinder one has no fuel to burn!
Installed another rack that I rebuilt - and, evidently, I'm not yet a good carb builder cause this rack ran like crap - choke had to be half on to run, popping and ugly.
Sync, even though done on bench,way off.
Good thing though, cylinder 1 head pipe had *some* warmth
Installed yet another rack I had rebuilt.
This time, MAGIC happens. Cylinder 1 instantly starts making heat, the the manometer shows fairly close readings from a bench sync, and both exhuast pipes now have good even pulses. So it's a carb related issue.
I do not understand two carburetor racks are not providing fuel to cylinder number one, and cylinder number two is working perfectly.
If it was one carburetor per cylinder, I would think fuel inlet issues, incorrect height in the bowl with a common bowl and number two looking great, but what could possibly cause number one to have no mixture across all 3 circuits?
Last edit: 5 months 3 days ago by dcarver220b.
Re: What would cause cylinder 1 to be dead but 2 - 6 are good?
5 months 1 day ago
#34764
     Looks like I'm on my own here..
From Gemini
=16pxA 1980 Kawasaki KZ1300 carburetor has a common float bowl and fuel level. There are two discrete carbuerator circuits inside one carburetor body. One circuit supply fuel-air to cylinder number 1. The other circuit feeds fuel - air to cylinder number 2. What would cause cylinder one to be dead when cylinder two works fine? Cylinder one has good compression, good spark, new spark plug, and spark can be seen when grounding the spark plug to the engine and cranking.        Since cylinder 1 has confirmed spark and compression, the issue is strictly a localized fuel-delivery failure within that specific carburetor circuit.Here are the causes that would make cylinder 1 dead while cylinder 2 runs fine: Blocked Pilot Circuit
  • Clogged Pilot Jet: The tiny orifice for cylinder 1's idle circuit is plugged with varnish or rust.
  • Blocked Passageways: Fuel or air bypass holes near the throttle valve are obstructed.
  • Misadjusted Pilot Screw: The idle mixture screw for cylinder 1 is turned fully in or blocked by debris.
 Mechanical Obstructions
  • Blocked Main Jet: Debris is sitting directly inside or on top of the cylinder 1 main jet.
  • Stuck Float Needle: If this specific model variation uses split internal feeds, one side may be starved.
  • Seized Throttle Valve: The slide or butterfly valve for cylinder 1 is not opening with the rest of the linkage.
 Air and Vacuum Leaks
  • Cracked Intake Boot: A cracked rubber manifold on cylinder 1 draws in unmetered air, leaning out the mixture completely.
  • Missing Vacuum Cap: A missing or cracked rubber cap on the cylinder 1 vacuum sync port destroys vacuum signals.
  • Bad Manifold Gasket: The seal between the intake tract and the cylinder head is leaking.
 Internal Structural Damage
  • Torn Diaphragm: If it is a CV (Constant Velocity) carburetor variant, a torn vacuum diaphragm prevents the slide from lifting.
  • Cracked Internal Body: A hairline fracture in the aluminum casting routes fuel or vacuum away from the venturi.
To help narrow this down, let me know:
  • Is the cylinder 1 spark plug wet with fuel or completely dry after cranking?
  • Does the cylinder fire briefly if you spray starting fluid directly into the intake tract?
  • What is the history of the bike (e.g., did it sit for years, or did this happen suddenly while riding)?
 AI can make mistakes, so double-check responses                                         =16pxCylinder 1 spark plug is dry across all throttle settings. The cylinder does fire if sprayed with starting fluid. Additionally, i have another carbuertor 'rack' that works good..        The dry spark plug and successful firing on starting fluid confirm that zero fuel is reaching cylinder 1, despite the shared float bowl. Since your alternative carburetor rack works perfectly, the engine itself is completely eliminated as the source of the problem.The issue is definitively an isolated physical blockage or mechanical failure inside the current carburetor body. Here is exactly what is causing the lack of fuel delivery: Clogged Internal Passageways
  • Plugged Main Fuel Well: The shared bowl feeds individual vertical towers or wells. The channel feeding the cylinder 1 side of the casting is completely blocked by varnish or debris.
  • Obstructed Jet Passages: Both the pilot jet and main jet orifices for cylinder 1 are entirely sealed by dried fuel residue.
  • Blocked Emulsion Tube: The tiny air-bleed holes along the sides of the cylinder 1 emulsion tube (nozzle) are gummed up, preventing fuel from climbing into the venturi.
 Mechanical Linkage and Vacuum Failures
  • Disconnected or Stuck Throttle Butterfly: If the throttle shaft is split or a linkage pin is sheared, the butterfly valve for cylinder 1 may be stuck closed while cylinder 2 opens.
  • Torn or Unseated CV Diaphragm: A tear in the rubber diaphragm, or a missing needle clip, keeps the cylinder 1 slide bottomed out, blocking all fuel flow at wider throttle openings.
 Complete Vacuum Loss
  • Massive Sync Port Leak: A missing vacuum plug or a cracked line on the cylinder 1 sync port drops the vacuum signal to zero, meaning the carburetor cannot "suck" fuel up from the bowl.
If you plan to fix this specific carburetor rack, let me know:
  • Do you want a step-by-step cleaning procedure to clear these internal channels?
  • Are you looking for tips on how to safely remove and inspect the internal jets without stripping them?
  • Would you prefer to just swap over the working alternative rack for now?
                                       =16pxPlease provide a step by step cleaning procedure          Preparation and Safety
  1. Workplace: Choose a clean, well-ventilated area.
  2. Safety: Wear eye protection and nitrile gloves. Carburetor cleaner is highly corrosive to skin and eyes.
  3. Tools: Grab a container for soaking, a can of aerosol carburetor cleaner, compressed air, a guitar string (or fine copper wire), and properly fitting JIS or Phillips screwdrivers.
  Step 1: Disassembly
  • Remove the Bowl: Flip the carburetor over and remove the float bowl screws. Lift the bowl off carefully to avoid tearing the gasket.
  • Remove the Float and Needle: Slide out the float hinge pin. Lift the float and the attached fuel inlet needle valve out.
  • Extract the Jets: Locate the separate pilot (idle) jet and main jet inside the central tower for cylinder 1. Use a flathead screwdriver that snugly fits the slots to unscrew and remove them.
  • Remove the Emulsion Tube: If the main jet sits inside an emulsion tube (nozzle), gently tap it out from the venturi side into the bowl area using a soft punch or wooden dowel.
  • Remove the Mixture Screw: Back out the pilot mixture screw for cylinder 1. Count the exact number of turns it takes to lightly seat it before removing it so you can replicate the setting later. Remove the screw, its tiny spring, washer, and O-ring.
  Step 2: Mechanical Clearing
  • Inspect the Jets: Hold the pilot and main jets up to a bright light. If cylinder 1 is dry, you will likely see a solid wall of varnish blocking the tiny center holes.
  • Clear the Orifices: Thread a thin guitar string or a single strand of copper wire through the jet holes. Poke through the debris gently. Never use hard steel wire or drill bits, as they will easily enlarge or scratch the precise brass orifices.
  • Clear the Emulsion Tube: Use the wire to clean all the tiny air-bleed holes running along the sides of the emulsion tube.
  Step 3: Chemical Soaking and Flushing
  • Soak the Brass: Place all removed brass parts (jets, tube, mixture screw) into a small container filled with carburetor cleaner. Let them soak for 15–30 minutes.
  • Blast the Internal Passageways: Insert the straw of the aerosol carburetor cleaner can directly into the pilot jet hole, main jet hole, and pilot mixture screw hole in the carburetor body. Spray forcefully.
  • Verify Exit Paths: Watch where the cleaner exits. It should spray freely into the main venturi bore through the tiny transition holes near the butterfly valve. If it shoots backward or doesn't exit at all, the internal casting channel is still blocked.
  Step 4: Compressed Air Purge
  • Blow Out Passages: Shoot high-pressure compressed air through every orifice you just sprayed. This forces out loosened chunks of varnish that the chemical solvent dissolved.
  • Dry the Parts: Blow compressed air through the individual jets and emulsion tube to ensure they are entirely clear of liquid and debris.
  Step 5: Reassembly and Verification
  • Inspect Rubber Parts: Ensure the mixture screw O-ring and the float bowl gasket are soft and free of tears. Replace them if they are flattened or brittle.
  • Reinstall Components: Thread the clean jets back into the cylinder 1 tower. Snug them down gently—brass strips easily.
  • Reset the Mixture Screw: Install the spring, washer, and O-ring onto the mixture screw. Screw it in until it lightly seats, then back it out the exact number of turns you counted during disassembly.
  • Reinstall Float and Needle: Drop the needle into its seat, hook it to the float, slide the pin in, and verify the float moves up and down smoothly without binding.
  • Seal the Bowl: Reinstall the float bowl and tighten the screws in a cross pattern.
To ensure a smooth reinstallation, would you like tips on bench-syncing the throttles before putting the rack back on the bike, or do you need help tracking down a rebuild kit for fresh seals?                                                       =16pxtips on bench-syncing the throttles         Bench-syncing ensures that all throttle valves open at the exact same time before you reinstall the carburetor rack. Since a 1980 Kawasaki KZ1300 uses a triple-carburetor setup (three dual-barrel carburetor bodies), synchronization is critical for a smooth idle [1].Here are the best tips to successfully bench-sync your throttles: 1. Identify the Reference Carburetor
  • Find the Master: Look at the throttle linkage to identify which carburetor is directly connected to the throttle cable pull. On the KZ1300, this is usually the center carburetor body (cylinders 3 and 4).
  • The Rules: You cannot adjust the idle height of the master carburetor independently. You will use its butterfly valve opening as the blueprint, adjusting the other two carburetor bodies to match it.
 2. Choose Your Measuring Gauge
  • The Wire/Paperclip Method: Use a thin, stiff guitar string (0.010 or 0.012 gauge) or a small, smooth paperclip.
  • The Solder Method (Safest): Use a piece of 1mm thick resin-core electrical solder. Solder is soft and will not scratch or nick the delicate brass throttle butterfly valves or aluminum bores if it slips.
 3. Set the Master Gap
  • Back Out the Main Idle Screw: Turn the main idle speed adjustment screw until all throttle butterflies are completely closed.
  • Set the Reference: Turn the main idle screw back in until the butterfly valve of your master carburetor just barely pinches your wire or solder against the bottom of the carburetor bore. There should be a slight drag when you pull the wire out.
 4. Adjust the Remaining Carburetors
  • Locate the Balance Screws: Look between the carburetor bodies on the linkage mechanism to find the spring-loaded synchronization adjustment screws.
  • Match the Drag: Insert your wire or solder into the bore of the carburetor you want to adjust (such as the cylinder 1 and 2 body).
  • Turn the Balance Screw: Rotate the balance screw until you feel the exact same amount of mechanical drag on the wire as you felt on the master carburetor.
  • Repeat: Move to the remaining carburetor body and repeat the process.
 5. Validate the Settings
  • The "Snap" Test: Open the throttle linkage fully by hand and let it snap closed a few times. This settles the springs and linkages.
  • Re-Check: Re-insert your wire gauge into every single bore to verify that the drag is still perfectly uniform across all barrels.
Once the rack is back on the bike, would you like guidance on how to perform the final dynamic vacuum synchronization while the engine is running, or do you need the factory specifications for the idle RPM?
  • BigSix
  • BigSix's Avatar
5 months 17 hours ago - 5 months 17 hours ago
#34765
Did you swap the spark plug to verify if that is the root cause ?
Last edit: 5 months 17 hours ago by BigSix.
5 months 15 hours ago
#34766
I guess we don't need the forum anymore if were going to artificial Intelligence for instructions.
I looked through your post with the Gemini responses. Following those instructions won't fix the problem. AI has, depending on what version, 2 types of deductive reasoning. 1 is an absolute,  if "A" then "B". The other anticipates what the next question will be and answers based on what it thinks might get you your requested info.
God help us.
5 months 14 hours ago
#34767
Thanks for the reply Holger. Yes, I did swap plugs, even put a brand new plug in the hole. It's definitely a carb issue as other carbs work great.
#34768
God help us.
Ironic you would mention the anti AI sentiment as I was reading, only 2 minutes ago, this article from the WSJ .
Regarding the forum - I posted my query 7 days ago and crickets. Maybe I expect too much from such a limited population, member wise. Which is why I though I'd try AI.
What specifically do you disagree with that AI produced?
I hope to investigate the 'bad rack' today. Yesterday I mounted yet another rebuilt rack and it works great. So I'm 2 out 3 rebuilt racks that work great..
Thanks for replying KB, know I appreciate your help.
