Leaky Pilot Jet O-Rings?
1 year 8 months ago - 1 year 8 months ago
#33419
 While rebuilding the carburetors, I noticed some small bubbles escaping from the pilot jet O-ring when using the scotch tool. That was with lacquer thinner.
Put some Snoop on the top and pressurized. Lots of bubbles!
I realize pressurizing is the opposite of vacuum and I am pressurizing at a higher pressure using my air compressor at 15 psi versus pulling a vacuum when the engine is running.Curious to see what the boys at K Z 1300.com say...
Last edit: 1 year 8 months ago by dcarver220b.
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Leaky Pilot Jet O-Rings?
1 year 8 months ago
#33422
IMO the O-ring should form a seal
1 year 8 months ago
#33426
Its impossable for an oring that small to withstand 15psi and the procedure, really proves nothing.
1 year 8 months ago
#33427
Thank You Scotch.
Is there any other way to test the seal?
Maybe have the bike running and inject ether into the area to see if RPM's increase?
D
  • Jafsteph
  • Jafsteph's Avatar
1 year 8 months ago
#33431
What i did was to set the pilot jets 3 turns out then covered the head with grease to form a seal{ temporarily } and see if it gets suck in when running
#33432
Good idea, Thanks for posting! Once I get this thing working and adjusted properly, I'll probably put a dab of  silicone to keep them from moving around. That 2 1/2 to 3 turns out they're kind of loose. Thanks again.
