Mixture still too lean
- kawaBCN
Re: Mixture still too lean
1 year 8 months agoWhat is your place of residence?Holger, the manual has that wrong. The correct plugs are BPR6ES and you can go to BPR5ES for a hotter plug if needed. I use the NGK BPR6ES Iridium equivalents and they are fantastic.Please allow a question from an amateur in reference to the topic discussed: if I ready right you are using NGK spark plugs BP...6.. - is that the correct temperature segment ?
The handbook I have is listing NGK BR8ES. Just wondering ... ?
What climate do you move through?
Cold, warm, temperate?
I say this because of the temperature rating used in the spark plugs.
- zed_thirteen
1 year 8 months agoThe UK, so just slightly warmer than yoursWhat is your place of residence?Holger, the manual has that wrong. The correct plugs are BPR6ES and you can go to BPR5ES for a hotter plug if needed. I use the NGK BPR6ES Iridium equivalents and they are fantastic.Please allow a question from an amateur in reference to the topic discussed: if I ready right you are using NGK spark plugs BP...6.. - is that the correct temperature segment ?
1 year 8 months ago
I'm running BPR6ES and live in 20F winter weather and 100+F summer weather.
Although, I don't ride the 'water heater' that much in summer. Too hot!
1 year 8 months ago
Hi guys,
Did ask the German community: most are using the NGK B... 6 ..
cheers,
cheers,
