Fuel mileage
Fuel mileage
3 years 3 months ago - 3 years 3 months ago
#31332
Damned right I framed it !
Conversion; 4.54L per Gal.
.6214K/per mile
The exact same ride at 120-140kph -  44.7 mpg.
Sorry....I don't "do" Liters per 100 kilometers.
The same weekend I did a short ride of  87K on the back-country roads.  "Twisting it" like an adolescent boy; I got  27.4 MPG !   The fuel needle dropped faster then the "Titan".
Last edit: 3 years 3 months ago by scotch.
Re: Fuel mileage
#31333
I'll assume there was no implosion at the end of the run ( unlike the Titan ) since you lived to tell the tale.
Gotta like those numbers. Pretty sure you own the pole position in the fuel mileage category. Congrats !!
  • Ted
  • Ted's Avatar
Re: Fuel mileage
#31334
I had to convert to US to see how that compares.  I was able to pull off a 46 miles per US gallon once which is close to yours, but that was with a low speed and sustained tail wind.
  • BigSix
  • BigSix's Avatar
Re: Fuel mileage
#31335
I tried to convert to litres per 100 km. Got 6,11 from Scotch´s data. Guess that is a good value, you probably won´t make it below unless you go slow to save fuel. That is roughly what I use.
regards from metric Europe ...
Re: Fuel mileage
#31336
Just a little off with the math Holger. He traveled 272.7 Kilometers using 13.285 liters. 272.7 KM= 2.727  100KM
13.285 liters / 2.727 (100 km) = 4.87 L/100 KM
Re: Fuel mileage
#31337
Ah, the joys of Imperial gallons vs U.S. Gallons vs Liters per 100 kilometers vs miles per gallon !
That's why I stay Ole School with M.P.G.  I simply can't grasp kilometers per liter.
Even simpler:  When it quits.....you're close to empty......switch to Reserve.  When that quits....your walking !   While hiking to the closest gas station you can calculate steps per 100 meters !
