Start the Motorcycle and accelerated alone
  • kzromero
  • kzromero's Avatar Topic Author
6 years 4 months ago
#27175
Hi folks! I have this trouble with one of my kz, i just cleaned the carbs and reassambly it in the bike then starts perfect but when I hit the throtlle the motorcycle stays accelerated and increase it alone. Any one have an idea?? Thanks
Re: Start the Motorcycle and accelerated alone
#27176
Hi,
If you have had the carbs off your bike and stripped for cleaning, they will need a full set up again to make then run correctly.
This includes mixture settings and syncronisation and cable adjustment etc, etc.
Search these on this site for full details.
The following user(s) said Thank You: kzromero
#27180
Vacuum leak will cause that.
#27183
Vacuum leak could cause that......................but pointless looking for a leak until the carbs are fully set up first...........or at least a good attempt !
  • rdurost
  • rdurost's Avatar
#27207
A very simple cause would be that the throttle cables are adjusted too tightly. This will prevent the weak spring from returning the throttle to idle. Does the RPM decrease to normal if you twist the throttle grip forward?
#27214
strate6 wrote: Vacuum leak could cause that.....
His problem may not be a vacuum leak but a vacuum leak will definitely cause the symptom he's experiencing. Easy to test for vacuum leaks with a little Quick Start.
Time to create page: 0.124 seconds
