1300 stock fuel-valve (petcock)
- stonehill
Re: 1300 stock fuel-valve (petcock)
7 years 9 months ago - 7 years 9 months agostrate6 wrote: Or you can always fit the VACUUM type petrol tap off a KAWASAKI GPZ900R,A4 /1988.
You will need to run a short vacuum pipe from your inlet track, which is easily done.
As this is a vacuum type tap, it stops petrol passing thru as soon as the engine stops running which is the reason they are fitted to modern bikes.
Thanks for posting Pete - that's a very good option. Do you happen to know if that tap fits a ZN model as well?
Last edit: 7 years 9 months ago by Bucko.
Hi Bucko,
I cannot confirm that.
It will be down to the pitch between the 2 mounting holes and direction of the fuel pipe to the tap.
Regards
Regards
Sorry mate...................what do you mean by "Does it go straight" ??
Time to create page: 0.125 seconds
