Throttle Hanging Open (Adjustment help requested)
- propav8r
Hi all, small issue on my '79. When I open the throttle and release it to close, the throttle doesn't close all the way. I have to remember to twist the throttle closed manually, or else the bike idles at 3000-4000rpm, and brakes poorly because it's still trying to accelerate.
Dangerous and unnerving.
So I pulled the tank off tonight and believe I've found the problem. When the throttle closes, the little roller (I'm gonna call it the "choke roller" for lack of a better term), shown by #1 in the photo below, comes into contact with it's stop before the actual throttle stop (#2) can contact at the back.
The throttle can be easily manually closed past this point, but I shouldn't have to do that.
Could anyone direct me to information on adjusting this? I can't seem to find anything, and there's no apparent adjustment for the choke roller.
Thanks!
Edit// disregard the "helper" return spring and the loose balance adjustment nuts. I added the spring to see if it helped (it doesn't) and was rechecking my carb balance.
Thanks!
Last edit: 7 years 8 months ago by propav8r.
Re: Throttle Hanging Open (Adjustment help requested)
Slide the choke-roller cam out of the way and see if the idle returns to normal. I'll elaborate based on the answer. It's likely due to some assembly errors/ misalignments which are easy to miss.
The following user(s) said Thank You: propav8r
- propav8r
7 years 8 months agoscotch wrote: Slide the choke-roller cam out of the way and see if the idle returns to normal. I'll elaborate based on the answer. It's likely due to some assembly errors/ misalignments which are easy to miss.
Yes, with that cam out of the way, the throttle closes as it should. If I so much as loosen the set screw for that cam by 1/8 turn, the throttle works as it should.
I didn't split the carbs off the rack when I cleaned them. Maybe I was hamfisted and bent something?
I'm looking at the choke cam and the profile doesn't look right. It appears to be teepee'd. Scotch?
- propav8r
Better pic. Thankyou. I'll leave this For Scotch to advise. He's our carb guru.
Last edit: 7 years 8 months ago by Kawboy.
Time to create page: 0.131 seconds
