How dangerous are leaky injectors?
  • AlexAmery
  • AlexAmery's Avatar Topic Author
#20396
Hello,
One of the fuel injectors on my car seems to be leaking pretty badly. There are two that have been problematic for some time. Today I noticed a distint smell of gasoline when I stopped in my driveway. I looked under the hood and and it seemed to be coming from one specifically. This is the first time I've ever smelled a remarkable amount of gas fumes from my car. How dangerous do you wise car-types think it is to drive to and from work - 20 miles one way, mostly freeway. It is my only car and since the entire rail needs to be removed to get to the injectors, they are fairly expensive to replace. I won't have enough money to fix them for probably close to a month. What say you, novice motor-heads?
Any help will be apprecited.
I didn't find the right solution from the Internet.
References:
arstechnica.com/civis/viewtopic.php?t=989123
Thank you.
Last edit: 8 years 3 months ago by KZQ.
Time to create page: 0.119 seconds
