Air filters
  • Sofiabg89
  • Sofiabg89's Avatar Topic Author
  • Largest 1300`s collection
Air filters
8 years 5 months ago
#19862
New air filters for our bikes in case your carburetor rubber grommets have started or are all ready cracked/perishing
  • Sofiabg89
Re: Air filters
#19863
They work great without rejeting! The 1300’s were build to run very rich to begin with
Re: Air filters
#19865
Having so many bikes, how many turns of A/F screw do you suggest on first start up? The manual says 1 1/4, but that's apparently very lean.
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Air filters
#19871
StanG wrote: Having so many bikes, how many turns of A/F screw do you suggest on first start up? The manual says 1 1/4, but that's apparently very lean.
Manual is wrong. Start at 3.5 turns
Re: Air filters
#19872
You'll not likely get the bike to start on only 1.5 turns. Every set of carbs I've rebuilt got set to an arbitrary 3.5 turns and then the Color-Tube 'tweaks" that setting.
Re: Air filters
#19891
Good stuff, thanks.
Anyone used wideband A/F meter? I have one and am wondering about mounting it on a steel rod and sticking it into the exhaust pipe besides the Colortune.
