Choke lever won't stay in place
  • charlie9670
  • charlie9670's Avatar Topic Author
9 years 11 months ago
#14817
My carbs are performing extremely well after strip, clean and new parts even though I've not done any balancing etc. It starts straight away on full choke but chugs a little on 1000rpm, after a few seconds I drop the choke lever half way down and it sits at 2000rpm running smoothly to warm up but I have to hold the lever in place as it snaps straight down if I let go. Not sure if this is normal or what I can do to remedy it so I can leave the bike on half choke for a minute to get warm and then tickover with the choke off?
:) Z13 UK
Re: Choke lever won't stay in place
9 years 11 months ago - 9 years 11 months ago
#14818
Best guess here is that you're missing one of the washers or the spring on the retainer bolt that holds the choke lever. Under the head of that shouldered bolt should be a spring, then a plain steel washer, then a duracon washer (fibre washer) then the choke lever, then another plain steel washer.
I like to use www.partszilla.com for exploded assembly drawings and part numbers.
This should help www.partzilla.com/parts/search/Kawasaki/...ETOR+ASSY/parts.html
Last edit: 9 years 11 months ago by Kawboy.
The following user(s) said Thank You: charlie9670
  • charlie9670
#14820
Just checked it and the screw wasn't tight enough..simple as , bit like myself had a screw loose :S thanks for the reply.
:) Z13 UK
Last edit: 9 years 11 months ago by charlie9670.
  • zed_thirteen
  • zed_thirteen's Avatar
#14827
Sometimes the shoulder on the shaft of the screw can tighten against the choke lever when you install it instead of the carb body - so it feels tightened.
Then when you move the choke lever it drops into the arc travel recess and becomes loose.
  • charlie9670
#14829
There is only the smallest amount of a turn between being loose and locking up but it's working now so I'll have a closer look when it comes in for the winter, I've got a spare set to rebuild as well so all bases covered carb wise...hopefully!
:) Z13 UK
