Rebuilding my carbs, NEED HELP !!!!!!!
- frankle951
I've taking my carbs apart to rebuild them, in the carb kit, there is a different choke shaft in the new kit, the old rod has a pin at the end and the new one don't have a pin, should I use my old rod or is there a new and improve rod ???????
When you wakeup please give thanks to God !!!!!!!
Last edit: 10 years 1 month ago by frankle951.
- Yaegunp
Re: Rebuilding my carbs, NEED HELP !!!!!!!
Yep that is confusing. I just used the old ones because I figured that pin was helping to centre the rod (aka Starter Plunger). That plunger has a sort of sealing gasket where the pin is and if that is in tact I don't see any reason why you can't use the old one. Having said that there are many folks here who are much more knowledgeable about this than myself.
1983 Z1300 A5 plus Sidecar.
- zed_thirteen
I think most people, myself included, just decided to carry on using the old ones
- frankle951
Thanks guys !!!!!!!
I put the new ones in, will take them out when I get around to it, full choke is too much, and she starts better with less than half choke, I guess the "pin" would also limit the amount of fuel getting out, live and learn
